HP (HeadPhone Impedance requirements
Posted: Mon Sep 11, 2023 9:35 pm
by Mark C
HI Guys,
First of all forgive my ignorance, I am old.
I have been searching and searching and can't find an impedance rating for the Headphone jack on the rear of my G2 100 radio.
The only reference I can find says impedance for external speaker is 4 to 8 ohms.
Does anyone know the impedance range for Head Phone jack in rear of radio.
Thanks for reading.
Re: HP (HeadPhone Impedance requirements
Posted: Tue Sep 12, 2023 12:25 am
See this topic: viewtopic.php?f=12&t=2612
If you look at the datasheet the answer is 16 or 32 Ohms.
Posted: Tue Sep 12, 2023 12:47 am
by Mark C
Thanks Jim for the information.
I looked at that diagram before I posted the question. Now after looking at it again, I am totally unable to figure out how you got 16 or 32 ohms.
Posted: Tue Sep 12, 2023 1:30 am
Scott, not Jim ;)
Did you review the datasheet like I posted?
Posted: Tue Sep 12, 2023 3:56 am
by w9ac
Mark C wrote:Thanks Jim for the information.
According to the datasheet, the TLV320 output Z at the headphone output pins is close to 0 ohms -- like many active amp stages. The spec sheet shows "Headphone-amplifier output load resistance" of 0 as a minimum but that doesn't mean you operate it that way, nor does it represent the output Z at the headphone jack. The reference to 16 and 32 ohms on the datasheet is the maximum power delivered into those resistances.
As an example, the Orion MKII board (and I believe Angelia) has 10 uF caps in series with a tapped RF choke between the TVA320 and the audio jack. Those components form part of the output Z at the headphone jack and it varies with frequency but it's always more than zero. Not having the G2 schematic set, it's only a guess on my part, but I suspect Apache kept the same headphone output circuit.
As an example of the Orion board at 100 Hz, the reactance at the headphone jack is -160 ohms in series with the choke resistance, let's say 10 ohms. The Z is 10-j160 but since the reactive component is much more than the resistive component, the result is slightly more than 160 ohms at 100Hz. But at 4 kHz, it drops to 10-j4. Now, the resistive component exceeds the capacitive component for a total output Z of about 11 ohms.
Bottom line: any modern headphones have sufficient impedance. The output jack Z changes with frequency just as headphone impedance changes with frequency. My Sony MDR-7506 headphones have an impedance spec of 24 ohms but Sony correctly caveats the impedance at 1 kHz although it's much different at the audio spectrum extremes.
P.S.
The RF choke has a small amount of inductive reactance that cancels the much larger cap reactance, but it's small enough to neglect at audio frequencies.
Posted: Tue Sep 12, 2023 4:08 pm
by Mark C
Sorry Scott....
Thanks Paul...yes I see on the diagram where it says Maximum output power, PO RL = 32 Ω and RL = 16 Ω.
Thanks for the help. Electronics theory and schematics were/are not my strong points. Morse code was far far easier than theory.
I do appreciate you all helping me understand how you ascertained the answers and hopefully someone else will benefit from this info.
73's
