HEIL PRO 7 Headset and G2 no display
Posted: Fri Jun 14, 2024 5:35 pm
Hi:
As a new G2 owner, I am about to attempt to hook up my HEIL PRO-7 dynamic headset (Mic and Headphones) to the G2's rear MIC port which is 1/8" or 3.5mm.
Looking at the Mic Jack on the PRO 7, it is a simple 3.5mm TS plug. Bill Diaz posted a G2 Microphone Examples diagram and as I understand that I need a 3.5mm TRS Stereo Breakout Adaptor with the T and S of the PRO 7 going to the TS of the adapter.
Then, I need to ground the other female port of the TRS Breakout adaptor such that the R (ring) is going to ground.
So to that end I did make up such a breakout adaptor.
Looking at Bill's example, (I have attached it below) where should I attach the ground wire to the G2? I could go to the rear ground wing-nut on the radio.
If any of you have integrated a PRO 7 to the G2 I would be greatly appreciative to hear from you.
Thanks 73
Art W1SWL
Thanks 73
Art W1SWL
