Digital audio interface connections
Re: Presonus Studio 192 Mobile audio interface
Postby w9mdb » Wed Apr 29, 2020 1:53 pm
How would one hook up the Steinberg unit?
To the speaker jack on the rig? Or somewhere else?
de Mike W9MDB
Postby Tony EI7BMB » Wed Apr 29, 2020 2:14 pm
I use VAC at present on UMC 204HD so Steinberg would be the same for me.
Postby w9mdb » Wed Apr 29, 2020 2:18 pm
That's the computer side...that I understand...
But how are you connecting audio from the rig to the audio interface?
Postby Tony EI7BMB » Wed Apr 29, 2020 7:06 pm
There is no audio connection from the rig , its a digital interface, all VAC
Postby w9mdb » Wed Apr 29, 2020 7:19 pm
So what is the connection from the rig then? Ethernet? If it's ethernet how does it get to the sound device? What's the digital path from rig to sound device?
I'm confused....I am, of course, familiar with the Ethernet via voice meter...
Postby Tony EI7BMB » Wed Apr 29, 2020 7:24 pm
Postby w9mdb » Wed Apr 29, 2020 7:44 pm
Color me dense...Scott's article mentions the Behringer...not how to hook it up.
These sound devices we're talking about have mic connectors that would have to have audio going in them to feed the USB bus coming from the device.
That's where I'm a bit confused as to where the audio gets into these devices.
On my ANAN 100 I have a headphone jack which would be too high for instrument level input to the device. Or use one of the line levels from the accessory connector that provides line level.
Postby w-u-2-o » Thu Apr 30, 2020 1:02 am
This is a placeholder topic
Postby w-u-2-o » Thu Apr 30, 2020 1:15 am
w9mdb wrote:Color me dense...Scott's article mentions the Behringer...not how to hook it up.
Sure it does.
That's correct. And they have audio outputs, too.
The audio goes into the device's mic connector and the audio comes out of the device's audio output connectors.
Think of it this way:
In the ANAN hardware unit (which is not a radio, it's just the hardware part, the radio is formed from both the hardware and the software that runs in the PC, i.e. PowerSDR or Thetis), inside that unit, say your ANAN-100, there is a custom "sound card". You can use that sound card to get receive audio out of PowerSDR (or Thetis), and to get transmit audio into PowerSDR (or Thetis). The mic, headphone and speaker connectors on the ANAN hardware unit are all connected to this "sound card" (note it's not a separate card, but it could be, all the circuitry just happens to be on the Hermes SDR board in there).
If you wish to use a sound card, or sound interface, that is inside or attached to your PC, you can do that instead of using the sound interface built into your ANAN hardware. However, to do that you need to use the so-called "VAC" interface that is built into PowerSDR and Thetis. By going into the VAC setup tabs you can select whatever sound hardware is attached to your PC and use that in lieu of what is inside the ANAN hardware.
Re: Digital audio interface connections
Postby w9mdb » Thu Apr 30, 2020 3:21 am
The only question I really have is what do you hook up from the rig to the Behringer (or whatever device). The headphone jack level could/would be too high and would have to be careful not to overdrive the Behringer...or do you hook up the line level pins from the accessory jack?
I would think the accessory jack but does somebody actually have it hooked up that way?
Postby w-u-2-o » Thu Apr 30, 2020 3:31 am
Unfortunately you are still not getting it, Mike. You don't physically make any connections between the ANAN and the audio interface (Behringer or otherwise--there is also Steinberg, Focusrite, Presonus, etc.).
Mic/Speakers <--> Audio Interface <--> PC <--> ANAN
With this configuration there are ZERO audio connections to the ANAN-100, ANAN-7000, whatever.
Don't forget the 90% of the radio is SOFTWARE. PowerSDR (or Thetis) does all the heavy lifting. The audio needs to get in and out of PowerSDR (or Thetis). If you connect mic's and speakers to the ANAN that's one way. If you connect mic's and speakers to a Behringer that's another.
The connection between the Behringer and PowerSDR is done in SOFTWARE.
Postby w9mdb » Thu Apr 30, 2020 3:50 am
Maybe where I'm getting confused is I thought we were talking about low latency. Why do you need low latency on Mic or Speakers plugged into an external audio device? What's the advantage vs just using the mic/spkr plug on the computer?
Postby w-u-2-o » Thu Apr 30, 2020 4:10 am
If you buy an interface that supports the ASIO driver standard it will have substantially lower latency than MME or WDM. With proper tuning, tweaking and settings it can have 10ms lower latency than using the connections on the ANAN.
A more obvious advantage is that you can connect professional microphones like large diameter condenser mics using fully shielded and balanced cable into a truly balanced differential amplifier input, including proper 48VDC phantom voltage if necessary, without any need to build special cables or screw around with balanced-to-unbalanced connections. You can get some really fantastic mic's like the Behringer B1 or MXL990 for under $100 dollars and connect them in a way that is highly resistance to RFI.
The ultimate advantage is that it lets you put the entire station elsewhere and run from a computer that can be in your office, or on your couch, or wherever, inside your home. See my qrz page for an example of this.
Postby w9mdb » Thu Apr 30, 2020 4:19 am
That makes sense....I'm 100% digital for several years now...but if I ever get into phone again sounds good...or CW....
I was trying to figure out how the thing would be for digital user...but I guess not better than ethernet for latency.
Postby w-u-2-o » Thu Apr 30, 2020 4:42 am
This is totally inapplicable to digital mode operations.
There should be no audio hardware involved with digi mode op's with our radios. Everything should be connected via software.
Postby Tony EI7BMB » Thu Apr 30, 2020 8:49 am
w-u-2-o wrote:This is a placeholder topic
Thanks for splitting this topic out Scott
