How to UMC204HD>Voicemeeter>LightHost>Thetis
Posted: Wed Mar 27, 2024 6:34 pm
does anyone use the Behringer U-Phoria UMC204HD together with Voicemeeter Banana and LightHost with Reaper VST plugins and Thetis.
I've never had anything serious to do with Voicemeeter and the configuration is driving me to despair.
OS: Win11, cmASIO key not entered in the registry.
In order to familiarize myself a little with the VM matter, I watched some videos on YouTube (e.g. https://www.youtube.com/watch?v=sT8k_aEIn3c)
Now I tried unsuccessfully to connect everything together for a few hours, but failed miserably.
I now know that first you have to select “UMC ASIO Driver” in “Hardware Out A1” in the main GUI.
Activate both channels in “System settings/Options” under “PATCH INSERT” under IN#1, and select the corresponding channel
under “Patch ASIO Inputs to Strips: IN1”.
Now the “UMC ASIO Mic.” automatically appears in the main GUI under “Hardware Input1”.
So far so good. But what happens next?
Which output to connect to LightHost and then to Thetis.
