Interfacing with ACOM amplifiers
Posted: Tue Nov 30, 2021 9:50 pm
I will be using an ACOM amplifier within a few weeks (depends on how bad the supply crunch is). My radio is ANAN 7000 DLE MKII (Black Edition).
The ACOM manual states (this is in regards to the "KEY-OUT socket" on the back apron of the amplifier):
"The KEY-OUT socket provides an extra control signal from the amplifier to the transceiver. It could be used to improve the transmit/receive (TX/RX) switching safety.
NOTICE:
KEY-OUT is a low-power open-drain output, make sure that the signal voltage coming from the respective transceiver connection does not exceed 50 VDC (open circuit) and the closed-circuit current is below 20 mA.
If your transceiver has a suitable input that disables transmission unless grounded externally, we recommend that you connect it with a shielded cable terminated in a Phono (RCA) connector to the KEY-OUT socket of the amplifier.
ACOM will operate normally with KEY-OUT unconnected if your transceiver has no such input........"
Am I being overly cautious in thinking that I may want to run a phono cable between the KEY-OUT socket of the ACOM and "Connector #16, Digital-IN" ("transmit inhibit") of the ANAN? In theory, this connection is NOT needed, but I would think having the cable there would be "extra insurance."
Would appreciate comments and thoughts on the above!
Best!
JJ
NOTICE:
Best!
JJ
