Amps with a PS sample Tap
PaulManc
Postby PaulManc » Wed May 25, 2022 10:14 am
A friend has two HPSDR radios and plans to use both independently but through an SPE V3 amplifier.
Radio 1 (Anan7000dle) goes into input1 and uses the -60db tap off the amp back to BYPASS. Output1 to the antenna.
Radio 2 (HL2) goes into input2 and uses a directional coupler xtronic on the Output2 and feeds a sample back to RX3 in the HL2
Not tried as yet BUT If radio2 is used and radio1 was switched on/off could any damage take place as I presume it will still be feeding the sample into Anan7000 :shock:
Many thanks in advance.
Paul
Manchester
Re: Amps with a PS sample Tap
Postby K1LSB » Wed May 25, 2022 2:20 pm
Logic would suggest that if the signal strength from the -60dB tap isn't great enough to harm radio1 while it's running then neither should it be harmful when it's not running.
Postby w-u-2-o » Wed May 25, 2022 2:50 pm
There will be no problems with this, for the reason that Mark already gave.
Instead of what he did, your friend could very have easily provisioned a 3dB splitter (not a T, but a real, low loss, hybrid splitter) on the amp coupled output. Example: Mini Circuits ZFSCJ-2-1. There are usually lots of these, or similar ones, available on eBay for $20ish dollars, give or take. They work great. I used one to split my GPSDO 10MHz output.
Or, for a lower loss solution (because the -60dB coupling factor of the SPE amps is already 10dB too low for optimum performance) he could have used the SPE AUX connector "/EN" signals to automatically direct an RF switch to feed the amp coupled output to radio 1 or 2 as appropriate. There always lots of Dow-Key coaxial relay switches for sale on eBay for not much money.
PaulManc
Postby PaulManc » Wed May 25, 2022 5:49 pm
Thanks gentleman for taking time out to reply, all welcomed.
Paul
Manchester
