Using THETIS SW to control a 200D can not control an external amplifier
Posted: Sat Jun 11, 2022 5:40 pm
Hello everyone
Now that I am using THETIS v2.8.11 software to control a 200D I am no longer able to
use the rear panel connection to control an external amplifier.
The THETIS User Manual says to use a USB-to-Serial port converter to control external
things like a CW-key and controlling an external amplifier. I would prefer to use the
DB-25 connector with some external wiring to control the amplifier.
HOW do I use the back panel DB25 connector pins to control an external relay that
switches the amplifier.
I played-with the General===>H/W Select===> HF settings in an effort to control
one of the 'connector pins' but had no success there.
Some hints/suggestions will be appreciated!
73 Dick/w7wkr
73 Dick/w7wkr
