Getting ready to operate in a big CW contest in May and exploring my options as far as keying the radio on CW is concerned.
I would like additional feedback from die-hard CW operators, especially those who are heavy into contesting!
Note that I am using a Solid State amplifier and will not want to see what an operator from the N1MM logging group.io page wrote:
***I stopped using the Thetis keyer function. Too often it had erratic timing leading to hot keying (evidenced by red flash around thetis display). Instead I now use an external winkey keyer. In N1MM+ you set this up in config. Enter the comm port assigned to the keyer (by windows), check keyer in N1MM+ configuration page. Click on set to choose winkey tab and click winkey.***
Old CW keying topic revisited
Thetis v2.10.4.3 x64
Protocol 2 v2.2.2
Protocol 2 v2.2.2
Re: Old CW keying topic revisited
Juha,
I use Thetis w/protocol2 on my 8000DLE driving a KPA-1500 and have no problem operating QSK with N1MM Logger+, or non-contest with an external paddle or CWX. I'm using delays of Key-Up=1ms, Key-Down=7ms.
Chris, W2PA
Chris, W2PA
Thanks Chris!
Not sure why this other Thetis fellow is having those issues. Perhaps he didn't set the timing parameters....
Protocol 2 v2.2.2
Protocol 2 v2.2.2
Chris,
What RF Delay (mine is set at 100) are you using? I see my PTT Delay is 0!
Protocol 2 v2.2.2
Protocol 2 v2.2.2
RX Delay 0
MOX Delay 15
RF Delay 7
PTT Delay 0
You'll need to experiment, of course. Everyone's HW setup is a bit different. Note that RF Delay doesn't affect CW operation according to the tool tip.
MOX Delay 15
RF Delay 7
PTT Delay 0
Chris, W2PA
Chris, W2PA
Copy that Chris!
Thanks.
Thanks.
Protocol 2 v2.2.2
Protocol 2 v2.2.2
W2PA wrote:MOX Delay 15
I've always wondered why one would want this parameter to be set to anything other than zero.
Can someone edify me please?
Bryan
W4WMT
Honestly, Bryan, I don't recall intentionally setting this. Maybe it was a default.
Chris, W2PA
Chris, W2PA
Yes, that is the default.
I could just never figure why.
I'm that "other" fellow.
In the manual, which admittedly is quite a bit out of date, it said set CW delays (both key up and key down) to at least 30ms otherwise will get unusual results. Indeed I found, with other versions of Thetis, this to be the case. That and the long delay needed for all the relays to switch.
The easiest work around was/ is the external keyer. PLUS, the note on every firmware update, that RF may appear on the receive only ports you set up for a brief moment when using the internal keyer. That is not what I want so another reason to not use the internal keyer.
Ron
N4XD
Ron
N4XD
