Although I despise Winwarbler, recently there have been some questions about how to set it up, so I did. I didn't attempt any transmissions with it, but it seems to work well enough on receive.
First ensure that RX1 AF is at 100%, VAC TX and RX gain is set at 0dB, and that you've set up some sort of virtual audio cable software in accordance with my VAC tutorial. Make the appropriate configurations of the virtual audio cable software (Voicemeeter Banana if you follow my tutorial).
Here are the two relevant setup tabs in Winwarbler. You can see in the first one I'm using Voicemeeter Banana and have selected the left audio channel.
In the second setup screen I've selected RTTY-R, as this will cause the correct selection of DIGU modeif you are effecting PowerSDR control via DX Commander, which I am. I dropped the stock waterfall gain to "3" and the FFT average is raise to "2". Those were the only changes I made to the defaults.
The resulting audio levels were actually too high. I had to drop VAC RX gain to -10dB.
Here is the result. Note that I carefully adjusted the squelch control towards the left end of the scale and my Vert Height to 2.0.
- Board index Hardware & Software Interfacing Digital Mode, Rig Control & Logging Software
- Search
- It is currently Sat Apr 27, 2024 9:36 am
- All times are UTC
Winwarbler setup
Jump to
- Apache Labs News
- Apache Labs News
- Client Software Discussion
- Thetis
- piHPSDR
- G2 Operating System & Applications
- PureSignal Operations (PowerSDR & Thetis)
- Diversity Operations (PowerSDR & Thetis)
- Macro & MIDI Controller Software, Hardware & Scripts
- PowerSDR mRX
- linHPSDR
- SDR Console
- All Other Clients
- Network Connections & Network Hardware
- Remote Operation Over The Internet
- Microphones, Speakers & Audio Hardware
- Digital ("Virtual") Audio
- Keys, Keyers, Paddles & Bugs
- Amplifiers & Tuners
- Digital Mode, Rig Control & Logging Software
- Transverters
- Apache-specific Hardware Discussions
- Everything Else: Antennas, Relays, Switches, Power, Grounding, Cooling, etc.
- PC's & Homebrew Hardware
- Firmware Discussion
- Upgrading/Downgrading
- Protocol 2 Firmware (all radios)
- Orion Mk II & III Firmware (all 7000, 8000 & Andromeda Variants)
- Orion Firmware (200D)
- Angelia Firmware (100D)
- Hermes Firmware (10 & 100)
- Hermes 14-bit Firmware (10E, 100B)
- Legacy Yahoo Group Files
- Other Topics
- Sales, Delivery, Warranty & Repair Discussions
- Forum Problems (like posting photos, etc.)
- Equipment Exchange
- Apache Labs Radios: Buy/Sell/Trade
