Release: AnanSplitIP
Posted: Sun Feb 20, 2022 2:38 pm
by oe3ide
another tiny tool :-)
What does this tool?
* read split state (ZZSP;), TXFilter state, zoom level
* if split is 1, it disables split (ZZSP1;) and restores TXFilter and zoom level
* if split is 0:
- read VFOA
- set VFOB to VFOA+5khz
- enables MultiRX
- enables display TX Filter
- set zoom level to 190
- enables split
The program uses TCP/IP-Cat (NOT TCI). To enable TCP/IP-cat in Thetis: goto Setup => CAT Control => CAT+
Settings via INI-file (in same folder as the executable):
Code: Select all
[Network]
Port=13013
IP=10.0.0.5
[Radio]
LastZoom=190
LastTXFilter=1
NoZoom=   (set to "1" for no zooming in split-mode)
OffsetHz=5000   (vfoa/vfob offset in Hz... default is 5000)
AnanSplitIP.zip
(7.64 KiB) Downloaded 422 times
