Anan 10e fpga heatsink size
nubbyless
Postby nubbyless » Sat Sep 05, 2020 2:25 pm
Hi does any one know of a schematic for the 10e so I can look up the exact fpga size I know it's a EP3C25 but there seems to be several packages I would like to add a stick on heatsink to it. I have seen some pictures where people have done this maybe someone knows what size I should purchase.
Fred
Re: Anan 10e fpga heatsink size
Postby w-u-2-o » Sat Sep 05, 2020 4:27 pm
Did you not notice the schematics section of this forum?
nubbyless
Postby nubbyless » Sat Sep 05, 2020 8:45 pm
thanks i searched and searched google and never found it i assumed if it was here i would of seen it in a google search but i was wrong sorry about that.
But after looking at that schematic it shows the ALTERA EP3C40Q240 which i believe is in the anan 10 not the 10e. although it may be the same size if the radios are identical otherwise
Postby w-u-2-o » Sun Sep 06, 2020 10:55 am
You are correct, that is the part used on the 10, they used the EP3C25 in the 10E to reduce cost.
I can only guess that they bought the same package type for the smaller FPGA so the board didn't have to be revised and got lazy on the schematic.
