Receiver preamp?
w8du
Receiver preamp?
Postby w8du » Fri Sep 17, 2021 5:25 pm
I just installed a "loop on the ground" antenna (see KK5JY.net) and it seems to be quite effective in many circumstances in improving SNR. However, it does have a lower level of signal strength. I was looking for a receive preamp in Thetis, but was unable to find it. Can someone direct me to the location in Thetis that allows me to engage and control a receive preamp (I am assuming there is such a feature)?
Thanks...73 de Arnie W8DU
Re: Receiver preamp?
Postby w-u-2-o » Fri Sep 17, 2021 5:36 pm
There is no switchable preamp in the hardware designs except on the 6M preselector path. In general, none is needed. On all Hermes, Angelia and Orion based hardware there is a fixed, 20dB gain differential amp which is designed specifically for use with the ADCs. On all Orion MKII based hardware that same amp is 14dB gain.
w8du
Postby w8du » Fri Sep 17, 2021 8:45 pm
Oh well. Thanks for letting me know that I was not overlooking it in Thetis.
73 de Arnie W8DU
