anan 200d lowest power output ( a m ) mode.
Platemodulation
Postby Platemodulation » Fri Jun 10, 2022 9:20 pm
I plan on operating a anan 200d I plan to operate mostly in the ( a m ) mode. What is the lowest power level I can run the anan 200d without affecting the audio and output.I am considering a low drive amplifier. Thanks and 73s.
KA1GXR
Re: anan 200d lowest power output ( a m ) mode.
Postby KA1GXR » Fri Jun 10, 2022 11:36 pm
1 watt carrier. Do not exceed 25 w.from the 200D.
DL2XY
Postby DL2XY » Sun Jun 12, 2022 3:35 pm
Minimum AM carrier is 0.25W at drive level 1.
If you need really small signal levels (0dBm) you may use XVTR output and disable the internal PA.
73 Walter
