100D problems
Posted: Fri Mar 10, 2023 9:45 am
by SILVA
Good morning. Please help me. My Anan 100D, only receives the RX2, would be the solution to make the bootloader? Thank you, Câmara.
100D problems
Posted: Fri Mar 10, 2023 12:11 pm
From your description there is no way to know what might be wrong with your 100D. It could be a problem with the hardware, software or firmware. It could be a problem with some other part of your station. It could be operator error.
Did it ever work right? When did the problem start? Did anything change at the same time the problem started? What have you done so far to debug the problem, why do you think reloading the firmware might be a solution?
P.S. I have moved your post to its own topic. Please do not just randomly post problems as replies to random topics that have nothing at all to do with your problem--posts should be on topic and, if not, then they deserve their own topic.
