7000DLE MKII - 9-pin connector pinout
Posted: Fri Jan 12, 2024 9:24 pm
I have a new-to-me black-face 7000DLE MKII (thanks Don and Chas!), and am trying to identify the correct pins on the 9-pin rear panel connector.
Thetis (Setup > General tab > OC Control sub-tab > HF sub-sub-tab) shows 7 control bits, labeled 1 through 7.
I found a silver-face 7000DLE MKII manual on the internet. It is dated 26 Feb 2019. On its p.17, it labels the OC pins OC0 through OC6, and maps them to connector pins 9 through 3, respectively. I could assume that OC0/pin 9 means Thetis 1, through to OC6/pin 3 means Thetis 7. You know what they say about assuming, so I must ask: do 0-6 map directly to 1-7 as I have stated above?
73, John W1JA
73, John W1JA
