Anan-10E upgrade to Firmware v1.5
Posted: Wed May 10, 2017 11:01 am
Firstly, this is the FIRST time I've ever attempted a firmware upgrade, so its probably something I'm doing but I don't know what as I'm following the instructions here in this forum and in the user guide.
I have a Anan-10E with firmware v1.3 working just fine.
I've used the HPSDRProgrammer previously to set a static IP address.
I would like to upgrade the firmware to v1.5 which I understand is the appropriate version for the Anan-10E.
I've installed HPSDRProgrammer V2 nopcap (version 2.0.4.10) 2014-7-2. When run, it successfully identifies my Anan of which there is only one as '00:04:A3:8D:3b:25 (192.168.10.60) Software version: 1.3 (hermes)'. I then select the file 'Hermes10E_v1.5.rbf' and 'Program'. The software then shows 'Erasing device ... (can take upto 40 seconds)' at the bottom of application window. But nothing else happens...even if its left for over 15minutes.
The HPSDRProgrammer still seems to work as I can select the small white rectangle under 'File' to view the log (see below) or 'Discover' to rediscover the radio again. I can even reselect the 'rbf' file and 'Program' again but still it does not proceed beyond 'Erasing device...'
What might I be doing wrong?
Log:
Attempting to discover HPSDR boards. (May take upto 12 seconds)
1 board found.
Opening file: C:/Users/agawthrope/Desktop/Hermes10E_v1.5.rbf
reading file...
file read successfully
Andrew
G0RVM
Log:
1 board found.
reading file...
Andrew
G0RVM
