Trouble using HPSDRProgrammer 2.0 and HPSDRBootloader 2.0
Posted: Sun Dec 29, 2019 12:14 am
I'm having a problem with both the programs mentioned above. I couldn't get either to work correctly. I read the Guides from beginning to end. I searched for terms relating to the errors I received . I did get a hit on one.
First I tried to use HPSDRProgrammer 2.0. I received an error stating it could not find the board and told me I may need to use Bootloader. The bootloader switch was in the correct position.
I moved to HPSDRBootloader 2.0. It did find the board. I read the IP address from the board. I thought it was unusual. It was 255.255.255.255.
I put a static IP of 10.0.0.101. I wrote it and it reported back that it was written to the board.
Next I moved to the next section that was named "Board Programmer" I browsed for the .rbf file I had downloaded. The file name is Orion_MkII_Protocol_2_v1.9 . It was listed on the github website under the 7000DLE/8000DLE download section.
I browsed for the file. WHen I selected it I received the error "HPSDRBootloader Proggrammer only write to boards with an ethernet connection! Use HPSDRBootloader as a JTAG programmer for c:\Orion_MkII_Protocol_2_v1.9.rbf "
I moved to the JTAG programmer section. I browsed for the same file and received an error interrogating the JTAG chain! Check that the correct interface is selected! Check that there is a jumper on J1 for Metis . HPSDRBootloader JTAG Programmer will on write to Mercury and Penelope/Pennylane boards! Penelope has been found! This rbf does not match C:\Orion_MkII_Protocol_2_v1.9.rbf
I searched and found one thread about this error and that it may have been caused by the way the file was downloaded from the github site. I downloaded it again. Same error. Did I download the incorrect file? Thanks for any help you may give.
