Interested in upgrading ANAN-100D
Posted: Mon Apr 13, 2020 4:14 pm
Just fired up a used ANAN-100D, using it on-the-air for a few weeks now, mainly phone, & having fun with it. It was originally purchased in November 2016. I installed OpenHPSDR mRX PS v3.4.9 on my Win10 I5 quad 3.1 GHz shack PC with 1GB ethernet & the Angelia firmware version is reported as v4.8. The ANAN-100D & PC are connected to an unmanaged LinkSys 1 GB ethernet switch.
I am interested in upgrading the ANAN-100D to the latest release of firmware & using the latest release of Thetis as a client.
I have read the 1st 3 pinned messages in this forum & believe I understand what I need to do to upgrade. Please allow me to summarize & I would appreciate any additional guidance:
-download & install Protocol 1 HPSDR Programmer, since Protocol 1 firmware is currently in the radio hardware
-download the latest firmware file: Protocol 2/Angelia (ANAN-100D)/Angelia_Protocol_2_v12.0.rbf
-follow the "Protocol 1 HPSDR Programmer Instructions" steps 1-9 in W2UO's pinned msg: "Guide To Using HPSDR Programmer and HPSDR Bootloader"
Questions I have:
-Will I need to change out the F3 fuse to a higher value?
-At what point during the firmware programming sequence should I change the ANAN-100D to a fixed IP with the Protocol 1 HPSDR Programmer? Before I program the firmware, then do another "discovery"?
-Can I downgrade the ANAN-100D back to the current version if the upgrade doesn't work?
Thank you for any assistance,
Phil WB9TAE
Questions I have:
Phil WB9TAE
