Protocol 2 upgrade problems 7000DLE mkII
Bricked your radio? Can't get it to program? Ask here...
W7SS
Postby W7SS » Fri May 05, 2023 6:12 pm
I've had my 7000DLE for a few years and finally decided to upgrade to Protocol 2 (V2.1.18).
Now Thetis (v2.9.0.6) doesn't show any activity RX on the panafall anymore.
The radio appears to transmit okay. After unkeying the transmitter the TX signal remains on the panafall display.
Any suggestions?
Ken (W7SS)
Re: Protocol 2 upgrade problems 7000DLE mkII
Postby w-u-2-o » Fri May 05, 2023 7:56 pm
The no RX, TX OK problem is Windows Firewall. Run the firewall check in Setup, disable/modify Windows firewall as necessary.
P2 uses different ports than P1 and your firewall is not set up for it.
W7SS
Postby W7SS » Fri May 05, 2023 11:34 pm
That fixed it, thanks.
Return to “Upgrading/Downgrading”
