Protocol 2 upgrade problems 7000DLE mkII
Posted: Fri May 05, 2023 6:12 pm
by W7SS
I've had my 7000DLE for a few years and finally decided to upgrade to Protocol 2 (V2.1.18).
Now Thetis (v2.9.0.6) doesn't show any activity RX on the panafall anymore.
The radio appears to transmit okay. After unkeying the transmitter the TX signal remains on the panafall display.
Any suggestions?
Ken (W7SS)
Re: Protocol 2 upgrade problems 7000DLE mkII
Posted: Fri May 05, 2023 7:56 pm
The no RX, TX OK problem is Windows Firewall. Run the firewall check in Setup, disable/modify Windows firewall as necessary.
P2 uses different ports than P1 and your firewall is not set up for it.
Posted: Fri May 05, 2023 11:34 pm
by W7SS
That fixed it, thanks.
