I'm at the point of my new installation that I'd like to incorporate PureSignal. So, I've been reading threads about couplers and talking to others on the air about this and still have some questions. A very common solutions seems to be the Xtronic XDC-4SO. However, it appears to be out of stock at the moment. I'm also exploring the LPA-100a digital meter with the PureSignal modification upgrade that Larry offers for a nominal fee. This seems like a reasonable choice as I would enjoy the metering capabilities while simultaneously resolving the coupler issue. Here is what Larry (N8LP) sent me when I inquired about the coupler modification:
"It consists of a resistive diver from the output of the coupler to ground, and terminates in a BNC connector. The BNC output is attenuated by 50 dB from the transmitted signal from 160 to 6 meters, and would normally connect to the PS input of your ANAN. When the BNC output is not connected to the ANAN, we provide a 50 ohm termination that can be screwed on instead."
As I understand it, the amount of needed attenuation is based on the amplifier output which make sense. I assume 50 dB is sufficient for 1.5KW and I'm wondering if there is a need to vary the amount of attenuation for lower outputs. For example, I'm using a KPA-500 running between 400-600 watts most of the time and may occasionally operate at the 100 watt level. At lower power, is the fixed 50 dB of attenuation a liability as compared to having variable attenuation?
In sum, I'm leaning toward the LPA100a with the ANAN modification as my coupling/metering solution and I'm seeking input before pulling the trigger. Please share your thoughts, experiences, concerns, and any other product recommendations that you may have.
73 Tim W8JJ
Coupler Solutions
Re: Coupler Solutions
Short answer
- maximum PS feedback level is set by the no damage max. input level to the hardware, which is +13dBm.
- minimum PS feedback levels needs to stay above -10dBm, below that PS performance will suffer. However higher input levels will provide better SNR vs. internal crosstalk; this is more of an issue for 200D and older hardware and less of an issue on 7000 and 8000 series hardware.
- a 50dB coupling factor is fine, will net a PS level of +12 at 1500W, +7 at 500W, 0 at 100W, and that is plenty fine for acceptable PS operation over that transmit RF power dynamic range. If you want to really guild the lilly, use a 40dB coupler and a 10dB step attenuator to fine tune for different power levels. Note that some amplifier vendors are offering 60dB coupled outputs and that is too much loss at lower output power levels.
Longer answer
- Read this topic: viewtopic.php?f=20&t=2384
Longer answer
Tim,
I built my own purely resistive non-directional RF sampler using a series/parallel arrangement of 2 watt 12K resistors (three pairs in series) to give me a total of 18K resistance (as an experiment I added another small bridge of three resistors to ground but those can be ignored for our purposes).
Here are some pics:
https://drive.google.com/drive/folders/ ... sp=sharing
NOTE: Disregard the variable pots in the box, those were used only for development and are no longer connected.
That arrangement is sufficient to allow PureSignal to get a solid lock at any power level from 25 watts (at 0 dB S-ATT) to the full 1KW output of my AL-80B (at 16 dB S-ATT), while still leaving plenty of headroom available to go well beyond full legal limit power with the Anan.
Here are some pics:
How important is it to have a directional coupler like the Xtronic unit? I have used the Xtronic coupler and a Coaxial Dynamics sampler that is adjustable.
http://www.coaxial.com/products/7998_7999.htm
I ordered a 7000 MK II Black Box last month. While I’m waiting for it to arrive I’ve been reading this forum and spending more money!
After reading the OP’s post I called Larry N8LP up and wound up ordering the LP-700 with a 50 dB sampler coupler so I will be ready for Pure Signal when the rig arrives.
I had ordered the Xtronic 44 dB Directional Coupler from HRO and it was on back order but it arrived today so there are some getting shipped out.
Not sure if I will sell the XDC-4SO or place it after my backup amplifier.
George / W7GES
George / W7GES
AG5CK wrote:How important is it to have a directional coupler like the Xtronic unit?
Theoretically a directional coupler will provide better results because there is no reverse power component carried back to the PureSignal receiver. However, I don't know if anyone has ever determined whether or not the difference is noticeable.
One of the advantages of the Xtronic coupler is that it has a very flat response over the entire HF frequency range. This make results consistent and repeatable. Other couplers and samplers may not exhibit the same gain flatness.
Finally, beware of adjustable samplers. On some adjustable samplers it is possible, with only a tiny movement of the adjustment, to greatly exceed the +13dBm feedback no-damage power limit. Careful measurement of output of such samplers and locking down any adjustments is recommended prior to connecting it to any Apache hardware.
w-u-2-o wrote:AG5CK wrote:How important is it to have a directional coupler like the Xtronic unit?
I felt like the directional coupler was better for that reason. It may make a noticeable difference with an antenna that that's less than ideal but close enough a tube amp loads up into it.
The other coupler I mentioned definately doesn't have a flat response and you do have to be careful. Now I just use it as a sampler for my oscilloscope.
Greetings, gentlemen. I've been reading the forum and enjoying the wealth of knowledge and expertise here. I figured I'd share my experiences with PureSignal in hopes that someone might find it useful and/or interesting.
Firstly, I'm not using an ANAN. I have a homebrew setup based on the Red Pitaya 125-14 which works as a 100D in Thetis, so keep that in mind.
I made a very simple resistive RF coupler using series 11k and shunt 50. It is connected to the output of the amp (TL-922) using a UHF-tee connector. This offers about -47dB coupling with practically 0dB return loss. I just used resistors I had "in stock" to derive the 11k. Using 16k/50-ohms would give a -50dB coupling. Inside the rig is a PE4302 step attenuator which Thetis controls with the "Auto Attenuate" feature. The RF inputs on the Red Pitaya are very hi-Z and I use transformers to help with this on the antennas, but for PureSignal I'm omitting the transformer. This may or may not make a difference.
This morning in preparation for this post I (quickly, had to go to work) fired everything up to take some screenshots. These tests were transmitting into an antenna, not a dummy load. As you can see, the IMD is pretty good even without PS. I seem to remember more of a difference between PS on/off the last time I looked at it but nonetheless, this is what I got this morning on 160m. I might do some additional testing later.
Nick W1NJC
~1400W or so:
~100W:
Coupler:
Nick W1NJC
~1400W or so:
~100W:
Coupler:
Nick,
That is awesome that you have Pure Signal functioning quite nicely with the Red Pitaya hardware! Thank you for sharing the details of your setup. I notice you have Pure Signal wrapped around the TL-922 with very respectable results. I've read with interest different things people have done with the Red Pitaya but you are the first that I have seen running something other than the ANAN with Pure Signal.
Nicely done!
Nicely done!
Thanks, Rob. I found your information and videos about configuring the audio chain in PowerSDR/Thetis to be quite valuable and well-presented. While I kind of "winged it" on the CFC EQs, I routinely receive unsolicited praise for my audio and signal!
I started perusing the forum to find out how people are sampling the RF for PureSignal. I see that most of the samplers are inductive. As noted above, mine is resistive and I was wondering if there was some advantage one way or the other. What I've done seems to work fine, the results are good, and my measurements don't seem to indicate anything problematic.
There's a lot of really good information in these threads and I've been trying to consume as much of it as I can.
Nick
Nick
Nick,
My homebuilt sampler is also pure resistive (18K ohms). I used that approach because 1) it's fairly linear (i.e., independent of frequency) and 2) to avoid any potential for undesired influence of inductive or capacitive reactance on PureSignal's operation. My memory is dim now but I probably decided on the 18K ohm value mainly because that's what I had in the parts jar.
Thanks, Mark. Well 18k/50 would give you -51dB so seems sensible. I put a shunt 50 on mine so whatever driving point impedance the PE4302 step attenuator presents is in parallel. Probably 50 ohms so maybe another -3dB. I don't think it really matters anyway.
Mine seems very linear. I think they are carbon resistors (they were OLD).
Nick
Nick
