ARRL Clean Signal Initiative
Postby w-u-2-o » Tue May 16, 2023 8:47 pm
Not strictly related to Apache hardware or openHPSDR software, but perhaps of interest to those of us who already have the cleanest signals on the HF spectrum. See the article in the June 2023 edition of QST, page 55.
The only mention of PureSignal, and not by name, is this one sentence in a three page article:
"Predistortion, a design technique known to help with signal purity and address IMD, is a currently niche feature available from only a few select manufacturers."
Obviously the software and firmware doesn't come from a "manufacturer". Supporting hardware includes Apache, Red Pitaya, Hermes Lite 2, and TRX Duo--am I missing anyone?
In fact, it seems that the author of the article, Mike Ritz, W7VO, and his reviewers and editors, went out of the way to discuss everything under the sun except for predistortion linearization.
Of course the single most important thing that anyone can do to clean up their act is to simply avoid pushing their amp past the 1dB compression point. Doing so is probably the cause of most band splatter. Not doing so is a simple idea that the article did not talk about much. But that will never happen because even if you are using a high end, (almost) peak reading RF power meter like an LP-700 it's still going to tell you that peaks are only at 1200W when you reach the 1dB compression point of your favorite, legal limit amp (give or take a dB). And since nobody is going to accept that ("I paid for 1500W, damn it!") that approach will never work.
The cool part about PureSignal (or any well-engineered predistortion linearization scheme) is that it acts like an automatic limiter for this sort of behavior. Keep turning the drive up and linearization will fight you tooth and nail, effectively turning it down as required to prevent putting the amp very far into compression.
Since building an HF amplifier in the kilowatt range with -50dBc spurious output is technically demanding and probably costly, linearization is almost certainly a much less expensive way to accomplish the same thing. Especially since even great amp's can be driven to be bad amps!
Both Elecraft and Icom are showing flashes of brilliance. The Elecraft K4 has a feedback input on the back, but no schedule for firmware to use it has been published. The yet-to-ship Icom PW2 amplifier is claimed to have the ability for "digital predistortion" when used with the IC-7610, but nobody has seen it yet.
Re: ARRL Clean Signal Initiative
Postby K1LSB » Tue May 16, 2023 11:01 pm
Flex has been claiming for over 8 years that their hardware is capable of adaptive predistortion, but still no implementation on the horizon:
https://community.flexradio.com/discuss ... tortion/p1
w9ac
Postby w9ac » Fri May 19, 2023 3:54 am
w-u-2-o wrote:Obviously the software and firmware doesn't come from a "manufacturer". Supporting hardware includes Apache, Red Pitaya, Hermes Lite 2, and TRX Duo--am I missing anyone?
Yes, if we consider predistortion development separate and apart from those involved with PureSignal. The ADAT ADT-200A transceiver was introduced in 2008 and from its beginning, predistortion has been a standard feature.
I owned one for three years before selling it, mostly due to a very buggy GUI, deep menu layers, and audible spurs from SMPS ingress. In this example, predistortion firmware is a design development from the manufacturer.
http://www.adat.ch/index_e.html
Dennis
Postby Dennis » Tue May 23, 2023 12:12 pm
Hi Guys, VIS-AIR has been running PURE SIGNAL for quiet some time, CHARLEY C-25 Project also,
plus one other radio from Eastern EU which I can not find the link,
https://charly25-sdr.github.io/
http://rus-sdr.ru/visair-2/
The above offers kit form or pre-built
ELAD Duo-X has a proto type but as far as it went,
had early ELAD FDM DUO 2013 - 2014 great SW, waited 4yrs for DUO-X nothing happened,
so back to Apache after 7yrs,
on the bench with FLEX for 9+yrs,
plus purchased an EESDR SUNDX-100W with the promise of Full duplex and PS2 in March 2020 nothing happened,
Apache just keep getting better Hardware and SW wise,
the New G2 will be a game changer I think, # 5 Apache ordered.
Dennis vk4sx
Postby w-u-2-o » Tue May 23, 2023 1:27 pm
Dennis wrote:Hi Guys, VIS-AIR has been running PURE SIGNAL for quiet some time, CHARLEY C-25 Project also...
So far, everyone except for the aforementioned ADAT radio is based on Warren's PureSignal by virtue of supporting a Protocol 1 interface to the hardware and thereby allowing PowerSDR mRX PS or Thetis to be used.
