dougmay6 wrote:Just received a 7000dle Mkll Black Edition radio today. I am getting the error message "Error starting SDR hardware, is it connected and powered?" After searching this forum and trying to resolve the problem, I decided to load PowerSDR and see what happens. Well, to my surprise PowerSDR runs perfectly. So what is different about Thetis that is won't run under the same conditions? Any help would be appreciated. Thank you.
Doug,
You don't need to follow the link Tony provided, all is working as it should.
Currently there are two different versions of firmware for ANAN hardware. They are known as Protocol 1 and Protocol 2.
Protocol 1 is what currently ships from the factory. It will work with PowerSDR mRX PS, piHPSDR, and linHPSDR. Personally I recommend PowerSDR because it remains the most feature-rich choice if not the prettiest.
Protocol 2 is currently in beta. It works with Thetis (a derivative of PowerSDR mRX PS), piHPSDR, linHPSDR, and SDR Console. Again, I recommend Thetis because it remains the most feature-rich choice if not the prettiest.
I would encourage you to read the "sticky" posts in the following two sub-forums here in order become more knowledgeable about the Protocol 2 firmware available for your hardware and how to load it:
viewforum.php?f=18viewforum.php?f=32The short answer is that P2 firmware doesn't reliably make timing on all serial numbers. You will need to find a version that works best on your serial number. I strongly recommend you use the Bootloader method for loading it (or going back to Protocol 1).
With that scary sounding statement out of the way, I say go for it! Almost everyone with a 7000 finds a version of P2 that works just fine, and the extra capabilities of P2 (larger IF sample rates, no restrictions on sample rate selection vs. PureSignal) are worth the effort.
Don't forget you MUST have a GigE connection between the PC and the hardware for P2 to work. It only runs at GigE speed. And you can't use Bootloader through a managed (smart) Ethernet switch, it must be a dumb switch.
