Direct Network To 10E
Posted: Sat Jul 24, 2021 11:58 am
Hello group,
I just purchased a used 10E and I have it working well with PowerSDRMRX and downgraded to protocol 1 with a network connection wired directly to my router. I removed the network cable from the router and plugged in directly to the computer and rebooted both the radio and the computer and waited a few minutes for APIPA to assign an IP ( i don't think this ever happened) and the network is 169.X.X.X I then opened up PowerSDR and it never finds the iP even after a power button press.
I am aware of the W1AEX site to connect by statically assigning the IP however for other reasons I rather not do that. My question is...Do I have to use the programming tool to delete the ip address that my router assigned it (192.168.1.55) to get it to accept a direct connection IP? or is there some other issue that dictates that I have to do a static ip?
Thank you.
Mike WA3O
Thank you.
Mike WA3O
