Interrupt Moderation setting on network interface
Posted: Mon Jan 24, 2022 9:06 pm
Here's an interesting one: on my Intel network interface card (NIC) I was doing some speed testing using iperf and was shocked to see the card only moving 150 Mbit/s. This is on a dual NIC, server type, PCIE card, and an i7 CPU, so it should be quite a bit faster.
After poking around in the advanced settings of the network adapter, I found that when I turned off "interrupt moderation" the transfer rate went up to 930Mbit/s! Needless to say I was quite pleased!
I'm not sure this has any real bearing on the performance of our radios, but I'd rather have a faster card than a slower card.
BTW, the challenge for this kind of testing is to have the iperf server running on something you trust to be faster than the PC you are testing. I installed iperf on my QNAP NAS server that has a 2Gbit connection to my switch and that worked quite well as a trusted server platform.
