Page 2 of 2
Re: Sequence errors during transmit
Posted: Fri Apr 07, 2023 8:00 pm
by W4WMT
w-u-2-o wrote:If it's doing that then it's probably firmware. I've not seen or heard of that error modality, though. Is this something you've actually seen?
Oh yeah. That's what I meant by "rewind" type sequence errors. I'll post a screen shot of one the next chance I get.
Posted: Fri Apr 07, 2023 8:28 pm
by n2gq
kc2rgw wrote:A dense stream of UDP like we generate is actually kind of unusual and brings out flaws in a lot of hardware/IP stacks.
To the OP, I'm curious what FPS rates and the FFT size being run. I've found people running some crazy combinations there and once adjusted to more sane values, their issues went away.
As for me I am running at default never messed around with fft and fps parameters.
Posted: Mon Apr 10, 2023 12:11 am
by n2gq
I have installed the beta above and have been operating most of the day with no sequence errors. I able to run at 768000 sample rate Pure Signal on.
Radio: Anan-7000dle mk3
Jay n2gq
Posted: Mon Apr 10, 2023 12:35 am
n2gq wrote:I have installed the beta above and have been operating most of the day with no sequence errors. I able to run at 768000 sample rate Pure Signal on.
Jay n2gq
Please report that in the beta topic.
Posted: Fri Jul 28, 2023 6:36 am
by StefanoAlvaro
w-u-2-o wrote:n2gq wrote:I am going to try a PS test today. Hopefully if I get time. Are any of you guys operating with a new mk3 chip and had any success?
Jay n2gq
Jay--AFAIK, you are the only person with the most recent FPGA that has reported an intractable problem with a GigE connection.
I'm pretty sure it's my same problem, stay tuned!
viewtopic.php?f=32&t=4485&p=23218#p23218
Posted: Sat Jul 29, 2023 1:53 pm
by n2gq
StefanoAlvaro wrote:w-u-2-o wrote:n2gq wrote:I am going to try a PS test today. Hopefully if I get time. Are any of you guys operating with a new mk3 chip and had any success?
Jay n2gq
Do you get a lot of errors?
Posted: Sat Jul 29, 2023 4:20 pm
by KC2QMA
With my new G2-100 I get errors from the time I start Thetis in receive as follows:
-Sequence error 256 (DDC2) in red
-Sequence error 256 (Mic) in red
-Sequence error 8 (DDC2) in red
-Sequence error 264 (DDC2 Mic) in red
Not sure what the issue is?
Posted: Sat Jul 29, 2023 4:55 pm
That doesn't bode well. The GigE interface on the Pi was supposed to fix this problem once and for all.
How are you connected between the PC and the G2?
Posted: Sat Jul 29, 2023 6:16 pm
by KC2QMA
w-u-2-o wrote:That doesn't bode well. The GigE interface on the Pi was supposed to fix this problem once and for all.
I am connected directly from PC to G2 via Intel I226V pci-E card.
-Other strange issue is with receive audio for example when I enable RX2 there is no audio until I stop and start Thetis again?
-I have not been able to get the balanced TRS mic input to work yet but may have not typed the -m xlr command correctly.
-No monitor audio from speaker or headphone outputs?
Posted: Sun Jul 30, 2023 2:06 pm
by StefanoAlvaro
n2gq wrote:StefanoAlvaro wrote:w-u-2-o wrote:Jay--AFAIK, you are the only person with the most recent FPGA that has reported an intractable problem with a GigE connection.
Oh yes, in the first minutes of transmission everything seemed to go well, but after a while (components that heat up perhaps?) they start and increase more and more. In 20 seconds it could happen even 4-5 times after about half an hour of transmissions
