You can't change an APIPA IP. They will automatically be assigned randomly over the range of 169.254.0.0 to 169.254.255.255.
Your choices are:
- APIPA assigned address. This address will be automatically set if there is no DHCP server and if no static IP is set in the ANAN.
- DHCP assigned IP address. To put any ANAN radio into this mode use the HPSDR Bootloader or HPSDR Programmer application to set the IP address to 0.0.0.0. And, of course, ensure that your ANAN is on a network with a DHCP server (usually your router).
- Static IP address. Again use HPSDR Bootloader or programmer to assign this address. Obviously you need to ensure that no other devices on the network are using that address.
For instructions on how to use HPSDR Bootloader and HPSDR Programmer see this topic:
viewtopic.php?f=18&t=2333Moving this thread to the networking forum...
