Orion MKII Protocol 1 Firmware Version 2.7 Released
Posted: Sat May 04, 2019 8:14 pm
Posting this for Joe, K5SO (k5so@k5so.com)
All,
I have reworked the timing on protocol 1 firmware for the 7000DLE/7000DLE MkII/8000DLE. This Orion_MkII_v2.7_K5SO_5-4 version works for the testers who have kindly tested it for me and it works fine here on 7000DLE and 8000DLE platforms.
This version includes the fixes implemented in recently posted versions that intended to fix Tx attenuator issues, including v2.4, v2.5, and v2.6 (and the non-public, "selected distribution" version of “v2.6” that is said to report as v2.4 that was being passed around by some people).
This v2.7 firmware version is an official HPSDR release version, fully public, that replaces those previous and various firmware versions that were previously undocumented and unposted on the HPSDR repository. Hopefully all future firmware versions will be properly released and posted before dissemination in order to avoid the confusion that has recently transpired.
It is my intention and expectation that this v2.7 version will function adequately on all 7000DLE/7000DLE MkII/8000DLE radios in the field but, should it not, I would appreciate specific feedback as to the model of radio you are using, and details of how you observe the failing event so that I may attempt to reproduce and remedy any such event.
The firmware is downloadable from:
https://github.com/TAPR/OpenHPSDR-Firmware/blob/master/Protocol%201/Orion_MkII%20(ANAN-7000DLE_ANAN-8000DLE)/Orion_MkII_v2.7_K5SO_5-4.rbf
Simply click on the “Download” button, don’t try to find a “releases” section on this repository page, there is none that contains anything of use.
Details of the changes made to create this firmware version are explicitly listed in the “Release_notes_Orion_MkII.txt” document on this page:
https://github.com/TAPR/OpenHPSDR-Firmware/tree/master/Protocol%201/Orion_MkII%20(ANAN-7000DLE_ANAN-8000DLE)
Thank you for your patience and testing.
73, Joe K5SO
Re: Orion MKII Protocol 1 Firmware Version 2.7 Released
Posted: Mon Feb 24, 2020 5:12 pm
by W2QO-Jamie
Yesterday I upgraded the firmware of my new Black Edition 7000DLE MKII from version 2.4 (Protocol 1) which was installed when I bought it from HRO about a month or two ago.
I installed 2.7 using the Bootloader method and everything appeared to be fine. But today I received an email from another operator telling me my signal was extremely wide.
I have made two screenshots using the TUN button and 1 watt of power. The first screen shot is with DUplex off and the second is with duplex on and it looks like something is certainly wrong with the signal.
I am using v3.4.9 software.
Tune with Duplex on.PNG (820.48 KiB) Viewed 13349 times
Can anyone point me int the right direction? I posted here because it was working fine until I upgraded the firmware but I realize there might be some other cause.
--Jamie, W2QO
Posted: Mon Feb 24, 2020 5:30 pm
Believe it or not, your drive power level may be too low. Below a certain drive power level the tune signal will go to shit. Try increasing your drive power level a little bit.
Posted: Mon Feb 24, 2020 5:41 pm
by W2QO-Jamie
Thank you for the speedy reply.
Here is another shot withDrive set to 20:
Higher power tune with duplex on.PNG (1.05 MiB) Viewed 13344 times
Posted: Mon Feb 24, 2020 5:47 pm
Oooh, that's ugly. If you go back to 2.4 does the problem go away? Or 2.6 or 2.5? This will help diagnose whether it is a firmware problem or a PowerSDR problem.
Posted: Mon Feb 24, 2020 6:19 pm
by W2QO-Jamie
Here is Version 2.6 Tune with higher power and duplex on.
Looks quite different.
v2.6 Gigher power tune with duplex on.PNG (1.1 MiB) Viewed 13337 times
Posted: Mon Feb 24, 2020 6:25 pm
Stick with 2.6 if it's working for you.
