P2 firmware not seen by Thetis
Posted: Tue Feb 23, 2021 3:05 pm
Hi all!
I have got an ANAN-7000DLE for repair. The problem with PTT always on was quickly fixed by replacing U29 on the OrionMKII.
But after reassembling the 7000 Thetis is unable to connect to the radio.
Disassembled again, using the Orion board alone, I tried different firmware versions. With P1 firmware programmed I can use PowerSDR to connect to the Orion board.
Both the 32bit and 64bit versions of Thetis fail to connect to the P2 firmware loaded Orion board.
Any hints?
Any hints?
