Bootloader Switch on 7K DLE MKII Black
Posted: Mon Dec 20, 2021 9:28 pm
Hi All,
I noticed my bootloader switch does not go all the way and doesn't seat positively.
Is there a way to test the switch without actually doing a firmware update? I have protocol 2 already installed using the programmer however, I want to fix the switch if it is an issue sooner than later in the event I need to use the bootloader vs the programmer.
thanks!
thanks!
