FW update instructions
PD3LK
Postby PD3LK » Tue Mar 22, 2022 12:20 am
Hope this is usefull for newbee's and VOM's ;)
Protocol 2 Firmware programming guide.pdf
(370.13 KiB) Downloaded 301 times
Re: FW update instructions
Postby w-u-2-o » Tue Mar 22, 2022 2:48 pm
The Apache forum link to the Orion MKII firmware is wrong.
Using a dropbox link is not recommended. Whose dropbox is it? Is it guaranteed to always be the latest?
WinPcap will still work but, yes, Npcap is probably preferred.
There is no discussion of Windows network metric settings or the use of Ethernet switches, either of which, if incorrect, could cause the process to fail.
IP addresses do not matter at all for Bootloader. Bootloader only uses raw Ethernet frames. IP addressing must be correct for Thetis to work, of course.
Instructions that are applicable to all hardware from the -10 to the -8000 can be found here: viewtopic.php?f=18&t=2333&p=2338#p2338
Return to “Orion Mk II & III Firmware (all 7000, 8000 & Andromeda Variants)”
