LOOKING FOR ALPHA TESTERS for ANAN-7000/Andromeda EP4CE and 5CEFA FPGA firmware update
Posted: Sun Mar 26, 2023 5:14 pm
by n1gp
This firmware is to fix an issue where there is no RF output with QSK CW selected.
This happens only on the Orion2 EP4CE and 5CEFA FPGA units.
See this thread for more info on the issue: https://community.apache-labs.com/viewtopic.php?f=14&t=4532
Note that it doesn't happen on the EP4CG FPGA (early MKIIs) so no new firmware there.
It would be advantageous if a few of the testers had access to a spectrum analyzer
to check for spectral purity during transmit.
Things to test using Thetis:
  • There is RF output with QSK CW selected
  • Pure Signal is working
  • ADC0 and ADC1 both work (route ADC1 from RX2 on back)
  • All Bands are working
  • Diversity is working
  • Wideband is working
  • Sequence errors do not happen on transmit nor receive
  • No jumping of noise floor where it sticks in high position
  • Attenuators are working
  • OC Controls are working
  • Ant 1-3 connectors are working
Please reply to this thread if your interested in helping to Alpha test either
the ANAN-7000/Andromeda EP4CE or 5CEFA FPGA firmware.
Once we get 4-5 or more folks I'll send out links to the Alpha firmware.
-Rick / N1GP
Re: LOOKING FOR ALPHA TESTERS for ANAN-7000/Andromeda EP4CE and 5CEFA FPGA firmware update
Posted: Sun Mar 26, 2023 6:22 pm
by rdwing
Definitely interested, I have access to other SDR's here as well as a spec an.
Thanks for all you do.
Posted: Sun Mar 26, 2023 9:48 pm
by W4WMT
Hi Rick,
I have an EP4CE equipped 7000 (also a spectrum analyzer) and would be happy to participate.
Bryan W4WMT
Posted: Mon Mar 27, 2023 12:52 am
by K1CWD
Hi Rick,
I can do some functional testing. I have a 5CEFA MKIII.
Out of curiosity are you using prime or II for development?
Craig K1CWD
Posted: Mon Mar 27, 2023 1:36 am
by NS8K
Rick,
Since I posted the original observation, I'd be happy to help out. Test equipment and knowledge is limited though. I have a 5CEFA MkIII.
Tom - NS8K
Posted: Mon Mar 27, 2023 11:54 am
by n1gp
Thanks guys.
I sent a PM to each of you.
Craig / K1CWD, I'm using Quartus Prime Lite 20.1
Posted: Sat Jul 29, 2023 7:48 am
by vk1hx
Would anyone happen to know if there was a P2 firmware version released, Orion_MkIII_CV_P2_v2.1.12D.rbf?
If so could someone send me a copy please? email is my callsign at hotmail.com
Regards
Posted: Sat Jul 29, 2023 9:54 am
by W4WMT
Yes, there was a "D" build, but it was DOA (according to Rick).
EDIT:
I meant to say, there was a Orion_MkIII_Protocol_2_v2.1.27D.rbf, is that the one you're looking for?
Posted: Sat Jul 29, 2023 10:30 am
You can still find the D version here:
viewtopic.php?f=32&t=4292#p21307
Posted: Sat Jul 29, 2023 2:20 pm
by vk1hx
w-u-2-o wrote:You can still find the D version here:
Thanks for the link Scott, however I'm looking for the CV version as posted: Orion_MkIII_CV_P2_v2.1.12D
I've got another Andromeda which wont run any of the P2 firmware files stable, constant sequence errors on RX and TX, Thetis lockups on RX and TX, PS not working, off frequency, the list goes on.
It came from the factory with Metis_Orion_MkII_v2.8_P1_CV_N1GP_9 installed. However, trying to get P2 to work is just not possible. All I know is that the P2 firmware files that will work partially are over 3mb is files size.
All the network tweaking has been set.
Posted: Sat Jul 29, 2023 4:53 pm
I've never seen such a version posted anywhere.
Posted: Sat Jul 29, 2023 9:12 pm
by vk1hx
I've tried the following versions of P2 firmware for hardware using the 5CEFA9F31 Cyclone V series FPGA.
Metis_Orion_MkIII_CV_P2_v2.1.12A
Metis_Orion_MkIII_CV_P2_v2.1.12B
Metis_Orion_MkIII_CV_P2_v2.1.12C
And the latest offering - Metis_Orion_MkIII_P2_CV_21.7
