EPCQ128A WITH ANGELIA
Posted: Sat Jul 17, 2021 9:41 am
by IK2LRN
Hi, i have garagebuild an Angelia radio , based to original ANAN bare board,
Since RAM EPCS-128 is not more available i have installed EPCQ-128 A.
I have tried to download in RAM bootloader pof with ALTERA BLASTER but it immediately totally fails.
https://github.com/TAPR/OpenHPSDR-Firmw ... (ANAN-100D)/Angelia_bootloader_source/Angelia_Bootloader_8Feb2014/Bootloader.pof
I have done successfully similar procedure with Hermes and Odyssey II.
If EPCQ-128 A is compatible please suggest me some troubleshooting actions.
Luca IK2LRN
Re: EPCQ128A WITH ANGELIA
Posted: Sat Jul 17, 2021 3:17 pm
The Angelia schematic shows an EPCS64. So at a minimum you probably need to obtain an EPCS64 or an EPCQ64.
On the Orion MKII this migration was done mid-stream in production as discussed here:
viewtopic.php?f=27&t=3081The same J14 appears on the Angelia schematic on Sheet 2 and the circuit appears functionally identical to that of the Orion MKII.
So you might try installing an EPCQ64 and also installing a jumper on J14, but that's a big guess on my part.
If you look at the datasheet of the EPCS64 and EPCQ64, the pinning and signal definitions appear compatible with the Angelia schematic. However, looking at the EPCQ64A datasheet, the Angelia schematic does not support that part. NC connections must be NC, not grounded, and in particular pin 3 cannot be grounded.
Posted: Sun Jul 18, 2021 2:12 pm
by IK2LRN
Hi, thank you for your answer.
When i open the pof file, with Quartus, it appears the indication EPCS128.
Please refer with attached picture.
The error messages are:
Error (209025): Can't recognize silicon ID for device 1
Error (209012): Operation failed
Posted: Sun Jul 18, 2021 2:30 pm
That's all the information I have. I don't know how to reconcile the difference between what you see in the code and what is on the schematic. Perhaps someone could look on their factory built Angelia and see what is there.
In any case, even if we assume the EPCS128 is the correct part, per the schematic the EPCQ128A would not work for the same reasons I already noted above.
I would encourage you to look at the data sheets and schematics for yourself.
Posted: Fri Jul 23, 2021 4:21 pm
by IK2LRN
Hi, since EPCS128 is not more officially produced i have ordered a Chinese clone at Aliexpress .
If someone have updated the bootloader software for EPCQ128 please contact me.
Thanks, 73
Luca IK2LRN
Milano Italia
Posted: Fri Jul 23, 2021 6:35 pm
by n1gp
Hi Luca,
Here is a QAR file for the bootloader FPGA code on the Orion2:
https://www.dropbox.com/s/veplw9xkt1wdu ... 2.qar?dl=0Perhaps this will help you figure out the changes you need.
73's
-Rick / N1GP
Posted: Sat Jul 24, 2021 7:32 pm
by IK2LRN
Hi Rick,
thanks for your help,
Luca
Posted: Sat Jul 24, 2021 9:42 pm
Looking at the code, in bootloader.v on line 19 it implies the use of the 128 size parts, and it implies support for the EPCQ128A with the jumper set properly.
I don't understand from the schematic how that can work, but maybe I'm missing something. Maybe I have an old/wrong schematic.
