Thanks Scott!
I already had FW v2.2.2 P2 on radio #1 and it didn't really work very well. Will roll radio #2 back to FW v2.1.18 P2 and see if that makes any difference. With regard to both radios looking "similar," I want them both looking as radio #1 does currently.
Update:
I guess radio #2 does not have the same FPGA that radio #1 has as after rolling back to FW 2.1.18 P2 the Thetis can't find the HW. Is there a later version of FW v.2.2.2 P2 that I might want to try instead?
Update2:
MAJOR PROBLEM cropped up! I tried FW 2.1.26 P2 as from another conversation with Doug (he wasn't a 100% certain which FPGA radio #2 had), surmised that by "going by the firmware v2.2.2 and the circuit board it most likely a EP4CE115F29C8N". Looking at the S/N of radio #2 and the thread at
viewtopic.php?f=32&t=4462, FW v.2.1.18 is what radio #2 would like to see!
I then decided to go back to the good-ole FW v2.2.2 P2 and SAME result, Thetis no longer detects the radio! NO FW works on radio #2!
I HOPE that I didn't BRICK radio #2. When using Bootloader, it does find the board and before programming it says "Erasing device...." or something like that and that it might take up to 90 seconds......ALL seemed to go well, with no errors reported. Exited, switched OFF radio and put Bootloader switch to OFF position, restarted radio. Thetis can't find radio #2 no matter which P2 FW version I try. I was expecting that Thetis would find the radio with the original FW v2.2.2 P2 programmed into it.
Update3:
Tried even rolling back to Protocol 1, but no joy. THEN, it hit me, I always hear a RELAY click upon starting Thetis (clicking on the "Power" icon) and there is no click of any kind. Perhaps this is a STUCK relay and has absolutely nothing to do with firmware! Would sure value comments, to save my sanity, again!!
Also, the right hand red LED stays lit, a solid RED instead of a blinking RED, which indicates the "heart is beating." Put in my radio #1 and all is well! So, I am thinking radio #2 has developed a hardware problem (relay?).
