New 100D Angelia Protocol 2 Firmware Topic
VK-JOE
Re: New 100D Angelia Protocol 2 Firmware Topic
Postby VK-JOE » Fri Oct 14, 2022 4:26 am
Just want to report that I am currently using a 100D with - as reported -> Thetis v2.9.0.6 (4/23/22) (Protocol 2 v11.7.0) MW0LGE
Firmware as reported via Setup is -
Ver: 11.7.0
Protocol 2 (v3.7)
I presume v3.7 refers to the version of the P2 protocol and not the specific firmware revision?
RX sample rate running at 76800
(even tried 153600 - RX only so far - no problems - CPU at 29% - its working hard ;)
would be nice to be able to monitor the FPGA temerature )
So far no problems - but I am only testing TX into dummy load - so perfect 1:1 SWR
Just wondering if there has been any more feedback (perhaps via other posts) on the various P2 firmwares available for the 100D - with respect to functionality with latest Thetis - obviously the version I am running is stable - so happy with this :D
But are there any "features" of latest Thetis that we might be missing?
Sorry for the newbie question :oops:
Postby w-u-2-o » Fri Oct 14, 2022 12:55 pm
Yes, 3.7 refers to the version of Protocol 2 interface documentation.
Wow, 11.7.0 is VERY old. It's amazing that it is working for you.
If you want to mess with success, the latest version is available for download from the first post of this topic. 11.7.0 is available from the bowels of the old TAPR repository here: https://github.com/TAPR/OpenHPSDR-Firmware/tree/master/Protocol%202/Angelia%20(ANAN-100D)/previous%20Angelia%20NP%20versions
VK-JOE
Postby VK-JOE » Fri Oct 14, 2022 6:24 pm
@w-u-2-0
Scott, thanks for the feedback.
I tried latest FW for 100D and various others going down the list
I found the following observations - hope it’s helpful for others...
VA2EY wrote:Pure signal correcting, not stable. Back with the version Angelia_Protocol_2_v11.7_7-15-18.rbf
The only one that works 95% with my device and those of my friends.
No version 12 is working yet
Same as @VA2EY comments above.
12.1.8 - constant ADC2 Overload when TX
12.1.6 - works on 40m and 20m
Also, FW Ver 12.XX reports PLL Locked (in Setup)
Ver 11.xx reports PLL not locked
Obviously more work was done in the Ver 12 release (larger files also)
Looks like the silent majority prefers Ver 12.1 pre4 - by virtue it’s got the most downloads (330)
Can you confirm any of the above (and which FW you use) - I presume you have a stable system when you operate your own 100D?
Postby w-u-2-o » Fri Oct 14, 2022 7:03 pm
I have perfect operation with 12.1.8 on my 100D.
My 100D is modified in accordance with this topic in order to ensure proper P2 firmware operation on the Angelia:
viewtopic.php?f=17&t=2777
Please address your concerns about 100D crosstalk in another (new) topic, probably in the PureSignal sub-forum. Such concerns are not relevant to P2 firmware discussions.
