Most "straightforward" way from P1 to P2 ?
JJ4SDR
Postby JJ4SDR » Tue Nov 16, 2021 1:40 am
I have had my ANAN 7000 DLE MKII for about 3 months now and haven't upgraded or applied any patches whatsoever as, on advice from "veteran" users I wanted to stick with Protocol 1 for a while.
Is there a thread that describes how to migrate from Protocol 1 to Protocol 2 (the most "stable" and solid version)? I have been using THETIS v.2.8.11 (10/20/20) till now.
Best!
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
Re: Most "straightforward" way from P1 to P2 ?
Postby w-u-2-o » Tue Nov 16, 2021 1:52 am
Not a Thetis topic, moving to the P2 sub-forum...
There is only one way from P1 to P2, and that is to load P2 firmware in your hardware and give it a whirl.
I suppose one might argue if this should be done using HPSDR Programmer or Bootloader. I'd strongly suggest Bootloader. It is a less ambiguous method, if a bit more complex.
Read the sticky posts here: viewforum.php?f=18
Then find the sticky post relevant to your hardware here: viewforum.php?f=32
and start with the latest version of firmware available.
If all else fails, go back to P1 using Bootloader.
JJ4SDR
Postby JJ4SDR » Tue Nov 16, 2021 3:35 pm
Thanks Scott!
Sorry for posting this in the wrong sub-forum.
Protocol 2 v2.1.18
