Hi all, this is Max IU4JNR.
In few days I should receive a pre-loved ANAN7000DLE MK2. I'm not new to SDR, I own a SUNSDR2DX and 2pro and I just sold a Flex6400. I also owned a HL2 and a Hamlab 160-10 based on Red Pitaya.
I try to figure out what is the best solution to exploit my Stream Deck Plus to make it works wih Thetis and it seems there are a couple of solutions. However, what i found in the community forum are "old" discussions, dated nov 22.
Just as a try, I made few keys assignment using the "hotkey switch" in the SD+ software. Although they works, the mouse should stay focused on Thetis to be effective. Having multi-monitor setup this is not going to work.
So my questions are: are there any news on interfacing SD+ ? Any SW like FRstack for Flex? what is the most used/easy solution which keep the focus on Thetis whatever the mouse pointer is?
Thanks in advance
Max IU4JNR
Stream Deck Plus, Again
Re: Stream Deck Plus, Again
Any luck? I have a stream deck that used with my Flex6500. It would be nice to use it once again.
Brent N9BC
Brent N9BC
N9BC
N9BC
I'm not a Stream Deck owner, but I believe it is as easy as using a set of .bat files that are executed on Stream Deck button presses to send CAT commands to Thetis.
If I were doing this, I'd install some version of netcat for Windows--I like ncat which is part of the nmap suite. Then you can issue commands like:
echo zzfa00018135100; | ncat -C 127.0.0.1 13013 --send-only
In that example zzfa is the CAT command, 127.0.0.1 is the localhost address, and 13013 is the TCP/IP CAT server port in Thetis. -C adds a CRLF, --send-only closes the connection immediately after sending.
Check out my Video on configuring the StreamDeck with Thetis, it works excellent.
Video
https://www.youtube.com/watch?v=V0_EHNZDLZI&t=65s
LoopMIDI Download
https://www.tobias-erichsen.de/software/loopmidi.html
Video
LoopMIDI Download
NY8T wrote:Check out my Video on configuring the StreamDeck with Thetis, it works excellent.
Video
LoopMIDI Download
Thank you Larry.
This is working very well for me.
73, Dan KM6CQ
Rock Solid for me so far.
- StreamDeck.jpg (193.63 KiB) Viewed 1710 times
Yes this is pretty cool Larry. Thank you for sharing the procedure with us.
- Screenshot 2024-04-26 at 16.43.51.png (641.23 KiB) Viewed 1604 times
- Screenshot 2024-04-26 at 16.40.48.png (630.37 KiB) Viewed 1604 times
- Screenshot 2024-04-26 at 16.41.02.png (587.58 KiB) Viewed 1604 times
