ANAN-7000, 8000 & Andromeda series
This is a read-only sub-forum. If there is some documentation that you would like to see posted here, please PM or email a moderator.
Postby w-u-2-o » Sun Apr 09, 2017 1:39 pm
Complete schematics continue to be not publicly available at this time. They are, however, available upon request. Please contact Apache Labs directly to obtain them.
As of 17 Feb 2023, Apache has approved public posting of the three different versions of the Orion MKII SDR card used in 7000, 8000 and Andromeda units.
Hardware using the EP4CGX150F896 Cyclone IV series FPGA
- ANAN-8000DLE (original version, 200W, not MKII)
- ANAN-7000DLE (original version, not MKII or MKIII)
- ANAN-7000DLE MKII, no serial number or serial number lower than DX8300497A
- Andromeda with serial number lower than DX8300497A (only 5 units built)
EP4CGX150F896 orion mkii rev5.2 Production.pdf
(264.08 KiB) Downloaded 336 times
Hardware using the EP4CE115F29C8N Cyclone IV series FPGA
- ANAN-7000DLE MKII serial number DX8300497A or higher
- Andromeda with serial number ending in -CIV
EP4CE115F29C8N orion_mkiii_civ_v1_5_6_4_021020.pdf
(248.27 KiB) Downloaded 263 times
Hardware using the 5CEFA9F31 Cyclone V series FPGA
- ANAN-7000DLE MKIII all serial numbers
- Andromeda serial number ending in -CV
- ANAN-8000DLE MKII (500W)
5CEFA9F31 ORION_MKIII_CV.pdf
(246.65 KiB) Downloaded 261 times
DE-9F 9-pin Rear Panel Accessory Connector Pinouts
Postby w-u-2-o » Sat Aug 26, 2017 9:08 pm
1-GND
2-OCREF
3-OC6
4-OC5
5-OC4
6-OC3
7-OC2
8-OC1
9-OC0
Orion Mk II J16 Pin-outs
Postby w-u-2-o » Fri Dec 15, 2017 2:19 pm
On the Orion Mk II boards, J16, the IDC type connector on the board used to make connections to the rear panel connectors, is identical to the equivalent connector on the 100D and 200D, with one exception:
In the 7000, or on 8000's manufactured starting Dec 2017, Pin 10 is no longer ground, it is now "BUFF_OUT", and is intended to be used with EER type amplifiers (not that there is any firmware that currently supports this).
Return to “User Guides, Schematics & Other Documentation”
