PA disable not functionnal
Posted: Fri Aug 02, 2019 12:04 am
Hi all !
When using the transverters i'm unable to disable the PA even with Disable PA chekbox checked in the
XVTR Setup form or in General/Antenna Setup.
When ever I transmit the PA will deliver full output (eg 60 Watts for an XVTR output of 0 dBm and up to max power when Xvtr power is set to
38.8 -max power- in PA vhf Settings)
I did'nt find which circuit cuts the bias to mute the PA and how it is working.
Who has an idea ? (ANAN 200D FW 1.8. Thetis 2.6.7 i7 4770k Win 10 64 pro)
73s Phil FM5GB
73s Phil FM5GB
