Re: How to post images?
Posted: Fri Oct 11, 2019 9:34 pm
by Segrest
Or if your image file is on your local computer, you can simply scroll the reply editor window down a bit, click the Attachments tab and select the Add Files button. This causes a popup window to appear you select the file you want from you computer and upload it. You can then decide if you want to insert inline with your comments or at the end of your post (the default choice).
Note that there is a limit on how big a file you can post. Convert those JPG images to PNG images and most will fit.
Bob
KO2F
