I need a replacement power cable for A-10E
k3rw
Postby k3rw » Fri Aug 11, 2023 11:18 pm
Somehow I misplaced the power cable for my A-10E, and none of my power cables seem to fit that middle pin.
I emailed support as well, but how can I order a replacement power cable?
Greg, K3RW
Re: I need a replacement power cable for A-10E
Postby Tony EI7BMB » Sat Aug 12, 2023 9:07 am
k3rw
Postby k3rw » Thu Aug 31, 2023 8:59 am
Thanks--I did email him and he told me (to my total surprise) 'it was not economical for him to make a cable I could easily make myself'. Economical is the word he used. I was directed to just build-my-own, which I would do, if I knew the specs of that rear connector. It seems a bit larger in the center than most of the things I tried.
My problem is, I can't find the specs of the middle pin to get a connector. I have several pins, none fit it. After going through several junk boxes I finally found one that worked.
I also emailed Apache Labs on their customer contact form, and never heard back. Second time now I've emailed about an issue and gotten no response at all.
Thanks for your help!
Greg, K3RW
Return to “Sales, Delivery, Warranty & Repair Discussions”
