What is a reasonable maximum heat sink temperature for a 7000DLE MK-II ?
I ask because I just stripped down an Andromeda and added a 120MM fan where the LCD used to be. Since I have lots of empty front panel, I decided to glue a 10K thermistor to the PA heat sink and put a display for it out front.
The display is actually a thermostat - along with a set of relay contacts that I probably won't use, it has a Sonalert-style beeper that beeps when the temp exceeds a pre-programmed level.
I was thinking 60C max directly across from the PA transistors. Normally you can't get there because of the positioning of the Orion MK-nnn board, but I'm raising the board off the PA heatsink so that I can get air moving between the two.
Thoughts?
Jim N7CXI
- Board index Hardware & Software Interfacing Apache-specific Hardware Discussions
- Search
- It is currently Mon Dec 04, 2023 10:45 am
- All times are UTC
7000DLE MK-II reasonable maximum heat sink temp?
Jump to
- Apache Labs News
- Apache Labs News
- Client Software Discussion
- Thetis
- piHPSDR
- PowerSDR mRX
- linHPSDR
- SDR Console
- All Other Clients
- Digital ("Virtual") Audio
- Amplifiers & Tuners
- Transverters
- PC's & Homebrew Hardware
- Firmware Discussion
- Upgrading/Downgrading
- Orion Firmware (200D)
- Angelia Firmware (100D)
- Hermes Firmware (10 & 100)
- Legacy Yahoo Group Files
- Other Topics
- Equipment Exchange
