Ext 10Mhz input level.
GW4NNO
Postby GW4NNO » Thu Feb 08, 2024 10:50 am
I have an Anan 7000DLE MkII. I also will soon have a GPSDO 10Mhz oscillator. The output level of the oscillator is approximately +7dbm. I want to know if it is safe to connect this oscillator directly to the SMA Ext 10Mhz input of the 7000. In other words, I need to know what input level range this socket can accept. Obviously if the level of my oscillator is too high I will have to use some form of attenuation between the oscillator and the 7000 Ext 10Mhz input. I can't seem to find any published specifications for the Ext 10Mhz input on the 7000.
Re: Ext 10Mhz input level.
Postby w-u-2-o » Thu Feb 08, 2024 12:07 pm
That will work fine.
See also this large thread on GPSDO use: viewtopic.php?f=17&t=2499
GW4NNO
Postby GW4NNO » Thu Feb 08, 2024 1:25 pm
Thanks very much! Excellent news.
Terry. GW4NNO
