Aside from a shelf, does anyone know if there's a rack mount available for the ANAN 7000DLE MkII?
KF4HR
Rack Mount for ANAN DLE-7000 MkII ?
Re: Rack Mount for ANAN DLE-7000 MkII ?
AFAIK there is no off-the-shelf product available at this time.
In a pinch, you can use a shelf, mount it up with a blank panel over the front of it, and cut an appropriately sized opening in the front panel.
Or, even better, order something like this (there are a million choices) and, again, cut an appropriately sized and located opening in the front panel.
There are two major manufacturers of amateur radio rack mounts. The first is:
https://www.snsengineering.com/shop
Fantastic products, my entire rack is full of them. I bet if you dropped SNS a line by email they'd be very happy to work with you to produce a 7000 rack mount.
The second is:
https://www.novexcomm.com/store.php?category=11
I've never had any dealings with those folks. You might drop them a line as well.
The second is:
