G2 Software and Firmware Updates
laurencebarker
Re: G2 Software and Firmware Updates
Postby laurencebarker » Tue Apr 02, 2024 6:43 pm
piHPSDR is in Christoph Wullen's repository:
https://github.com/DL1YCF/pihpsdr
but there are likely to be experimental changes there. I know that the current commit hasn't been tested yet, because Christoph does not have a G2. I won't be home to test that until Sunday earliest.
I will ask him if the long term version can be updated.
The build instructions haven't been changed.
gw0hyu
Postby gw0hyu » Tue Apr 02, 2024 9:46 pm
I notice saturnprimary2023V13.bin is loaded up on github, is this good to load on G2 without front ? :)
Cheers
Keith
gw0hyu
Postby gw0hyu » Tue Apr 02, 2024 9:56 pm
also just to mention that on my G2 using Thetis v2.10.3.6 setup / general shows
Firmware version 2.0.0 Id:
Saturn Protocol 2 (v3.9)
So dumb question , how does this relate to the latest firware version ? In other words I should see Saturn Protocol 2 (v12) when updated or is this not reference to the bin file ? :)
gw0hyu
Postby gw0hyu » Tue Apr 02, 2024 9:57 pm
gw0hyu wrote:I notice saturnprimary2023V13.bin is loaded up on github, is this good to load on G2 without front ? :)
Cheers
Keith
Just read the release notes , so guess the answer is no for now.. :D ..
Chris_sq8ers
Postby Chris_sq8ers » Wed Apr 03, 2024 6:40 am
Where can I download the SD card image for Anan G2 LCD?
Regards Chris
Roger GT
Postby Roger GT » Wed Apr 03, 2024 7:46 am
Where can I download the SD card image for the Anan G2 LCD?
I would also like to know this. The link in the manual does not work!
Vy 73 Roger DL2YDP
laurencebarker
Postby laurencebarker » Wed Apr 03, 2024 9:57 am
Chris_sq8ers wrote:Where can I download the SD card image for Anan G2 LCD?
Regards Chris
That's a question for the factory. Abhi was going to tell me when he had a stable location, but hasn't told me yet.
WM7C
Postby WM7C » Wed Apr 03, 2024 3:13 pm
Roger GT wrote:Where can I download the SD card image for the Anan G2 LCD?
Look in the Saturn Manual for the links.
Oh!!! Sorry, links are dead.
2024-04-03 08_11_49-1023_Saturn-manual-V08.pdf - Foxit PDF Reader.png (153.14 KiB) Viewed 1822 times
gw0hyu
Postby gw0hyu » Wed Apr 03, 2024 8:10 pm
gw0hyu wrote:also just to mention that on my G2 using Thetis v2.10.3.6 setup / general shows
so answered my own question which was dumb :) Updated to V12 as per Laurence' instructions a few posts ago and all went perfectly well.
Roger GT
Postby Roger GT » Thu Apr 04, 2024 8:15 am
4. Download a drive image from Apache Labs:
a. With display:
https://storage.googleapis.com/anan_g2/ ... _image.img
b. Without display:
https://storage.googleapis.com/anan_g2/ ... mage_27082
Both links do not work!
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>UserProjectAccountProblem</Code>
<Message>The project to be billed is associated with a closed billing account.</Message>
<Details>The billing account for the owning project is disabled in state closed</Details>
</Error>
Vy 73 Roger DL2YDP
K5WC
Postby K5WC » Fri Apr 26, 2024 12:06 am
Today I updated my P2APP to the latest version, all went well and after starting the P2APP on the G2 it shows the new version number but on transmit I have a occasional blip where the SWR red box flashes up on Thetis and I hear the relay click as it has dropped out the transmitter on the G2 for a split micro second. Pure signal drops red and the goes back green as recalculates. This does not happen every time I transmitted but also didn’t matter if PS was off or on. SWR is flat on my antenna. I went back to the previous version of P2APP that I had been using and everything is back to normal. Not sure if it’s just mine or if anyone else is seeing this anomaly on transmit.
Best 73, K5WC
coaxjim
Postby coaxjim » Sun Apr 28, 2024 3:09 am
Anyone have an image of the SD card for the G2 with display.?
I foolishly also did an update to the Pi, and now all screens are Black, as I read above happening to others.
Have Apache Labs not paid teir google storage account? Why isn't such important data files as these available from their website?
Radio is a door stop without software.
Tony VK4PA
laurencebarker
Postby laurencebarker » Mon Apr 29, 2024 7:51 pm
K5WC wrote:Today I updated my P2APP to the latest version, all went well and after starting the P2APP on the G2 it shows the new version number but on transmit I have a occasional blip where the SWR red box flashes up on Thetis and I hear the relay click as it has dropped out the transmitter on the G2 for a split micro second. Pure signal drops red and the goes back green as recalculates. This does not happen every time I transmitted but also didn’t matter if PS was off or on. SWR is flat on my antenna. I went back to the previous version of P2APP that I had been using and everything is back to normal. Not sure if it’s just mine or if anyone else is seeing this anomaly on transmit.
Best 73, K5WC
Can you load and try new p2app software V20 please?
(FPGA "as is" just the software)
I think this happened if you changed frequency (eg RX2) during TX, or some other change to settings
K5WC
Postby K5WC » Mon Apr 29, 2024 10:02 pm
Best 73, K5WC
Thank you Laurence for the update, I have it loaded and have been ragchewing for about a hour without any issues.
73 John K5WC
coaxjim
Postby coaxjim » Mon Apr 29, 2024 10:11 pm
coaxjim wrote:Anyone have an image of the SD card for the G2 with display.?
Tony VK4PA
Thanks to Abhi at Apache Labs.
For sending me a link to download the display G2 SD Card Image file.
Others who accidently trash their cards may be helped.
https://www.dropbox.com/scl/fi/6s7a4p34 ... clsuf&dl=0
All the best
Tony VK4PA
K5WC
Postby K5WC » Tue Apr 30, 2024 12:13 am
Tony VK4PA
All the best
Tony VK4PA
Thanks Tony for the link, did it get you back up and going?
73 John
Roger GT
Postby Roger GT » Tue Apr 30, 2024 8:34 am
K5WC wrote: Thanks Tony for the link, did it get you back up and going?
73 John
Thanks for the link Toni. I will test the image immediately. Stay tuned.
Vy 73 Roger DL2YDP
Roger GT
Postby Roger GT » Wed May 01, 2024 7:44 am
The image works. I have successfully flashed it onto a µSD card. The G2 is working and I just need to do the updates.
Vy 73 Roger DL2YDP
Gibo
Postby Gibo » Sun May 05, 2024 11:39 am
Anyone looking for the G2 no display SD card image it can be found here https://cacelense.pt/G2/G2_No_Display_p ... 021223.zip
VK8BN
sq9rst
Postby sq9rst » Wed May 08, 2024 7:35 pm
Gibo wrote:Anyone looking for the G2 no display SD card image it can be found here https://cacelense.pt/G2/G2_No_Display_p ... 021223.zip
VK8BN
Thank you!!!
73, SQ9RST
