Over-Clocking the G2 Raspberry Pi 4 Compute Module
Posted: Sat Sep 16, 2023 8:53 pm
For anyone interested in over-clocking the Raspberry Pi 4 CM from 1.5Ghz to 2.147Ghz:
Run Terminal and type "sudo geany" press enter.
Open the /boot/config.txt file.
Enter in the folllowing after the Uncomment to overclock the arm.
over_voltage=6
arm_freq=2147
gpu_freq=750
Then Save and close down menu.
Reboot...
Open another terminal, and type:
sudo watch -n 1 vcgencmd measure_ clock arm (to monitor cpu speed
or
sudo watch -n 1 vcgencmd measure_temp (to monitor cpu temp) mine stays at around 43 degrees C
John
N2KBE
over_voltage=6
arm_freq=2147
gpu_freq=750
Reboot...
or
John
N2KBE
