Record playback feature
cleanrf
Postby cleanrf » Sun Dec 16, 2018 5:41 pm
The record/ playback feature does not work for me when using VAC. It works normally if I am using the microphone jack on the front of the anan 10E. Any suggestions?
cleanrf
Re: Record playback feature
Postby cleanrf » Sun Feb 24, 2019 4:12 am
I still have not figured out what is causing this or a fix. Any suggestions?
Postby w-u-2-o » Sun Feb 24, 2019 11:43 am
What part of the process is failing for you? Record, or playback?
cleanrf
Postby cleanrf » Sat Mar 09, 2019 8:47 pm
The playback, I can record myself to use for setting up CFC but I cannot hear myself or see it on playback why MOX is enabled, I can hear and see it if I play it back without keying up the radio, no MOX.
cleanrf
Postby cleanrf » Sun Mar 24, 2019 4:13 am
Install with clean database due to other issues, still have the same issue. Any suggestions?
w4cm
Postby w4cm » Mon May 13, 2019 1:59 pm
Having issue with playback/ record feature.
Will record but not playback on-air. Using onscreen red dot for record and green arrow for playback.
7000DLE and Thetis 2.6.7 installed.
Also when I playback recorded audio the panadapter signal shows a double sideband signal.
I key the radio then hit play but no audio. I do see the signal peaking on the VOX bar when it is playing back but does not transmit audio over air.
I can record my voice and playback and transmit audio is fine.
Tried reload of 2.6.7 and also 2.6.6.
Any ideas please ?
Cecil
W4CM
DL2XY
Postby DL2XY » Wed Sep 11, 2019 7:49 pm
Mark one or more of the following Checkboxes for your prefered method of TX activation:
Setup/Audio/VAC1/Checkbox "Allow PTT to override/bypass VAC for Phone"
Setup/Audio/VAC1/Checkbox "Allow MOX to override/bypass VAC for Phone"
Setup/Audio/VAC1/Checkbox "Allow SPACE to override/bypass VAC for Phone"
73 Walter
w4cm
Postby w4cm » Thu Nov 07, 2019 12:51 pm
DL2XY wrote:Mark one or more of the following Checkboxes for your prefered method of TX activation:
73 Walter
w4cm
Postby w4cm » Fri Nov 08, 2019 1:52 am
An old issue has started again, no audio playback from recorded message in transmit.
I see the presence of audio when in playback mode via the up and down levels on the VOX bar but the transmitter shows no output
When I try playback on transmit I have tried keying MOX first then play and visa versa but no audio is being transmited over the air.
I can record my audio and it will playback audio on transmit.
I am using a CW ID program RoMac and it does use VAC when iy transmits the ID.
I have tried checking all three boxes in the audio tab, MOX, Space bar, PTT that overrides VAC, nothing helps.
Anan 7000DLE 2.6.9 a3
Cecil
w4cm
Postby w4cm » Fri Nov 08, 2019 5:23 pm
w4cm wrote:An old issue has started again, no audio playback from recorded message in transmit.
Cecil
FIXED
Postby w-u-2-o » Fri Nov 08, 2019 5:42 pm
What fixed it?
cleanrf
Postby cleanrf » Thu Dec 26, 2019 8:49 pm
Ditto, what fixed it Cecil?
Return to “PowerSDR mRX”
