Wave Record and Play
W6LVP
Postby W6LVP » Tue Aug 28, 2018 9:06 pm
Sometimes it is nice to be able to record a receive audio snippet and then play it back so another op can hear how they sound. I am new to this radio and software so I am sure the answer to my question is simple. Using the REC and PLAY buttons in the upper left block, I can record audio and the play it back during receive. When I key the transmitter, I don't get any modulation.
Larry
W6LVP
W6LVP
Re: Wave Record and Play
Postby W6LVP » Tue Aug 28, 2018 11:31 pm
I know it's not good form to reply to your own post but I figured out the solution to my earlier question.
I use two antennas connected to both receivers for diversity. I listen to one antenna on the left and the other on the right. Transmit only uses left audio which was the side I was using for RX2.
Postby w-u-2-o » Wed Aug 29, 2018 3:31 am
Take a look at this topic, particularly the W1AEX post on 20 Dec:
https://apache-labs.com/community/viewtopic.php?f=6&t=2620&p=4613
Return to “PowerSDR mRX”
