Github with source code: https://github.com/ew8bak/pihpsdr
Short instruction: first of all you need to install the gtk3-runtime-3.24.31 library, then open the PihSDR_bin folder and run the pihpsdr.exe file, after which the installation will begin. Next, go to the network settings, and create a rule for incoming and outgoing connections.
Instructions are on Github as well. I attached installation file. GTK Windows library you can download here https://github.com/tschoonj/GTK-for-Windows-Runtime-Environment-Installer/releases/download/2022-01-04/gtk3-runtime-3.24.31-2022-01-04-ts-win64.exe
By the way, work on linHPSDR on Windows are underway as well
