Panadapter Line Width
Posted: Fri Nov 11, 2022 7:58 pm
I made a very simple modification to the source so that I could run piHPSDR on an RPi connected to a 1024 x 600 display. When the resolution of the display increases, line widths scale down which makes it difficult to see the panadapter signal line. I can fill in the panadapter which helps but I prefer not to use fill in. Can someone suggest what to change in the source to make the panadapter signal line wider and maybe change the color?
Larry
W6LVP
Larry
W6LVP
